TwinTurbo.NET: Nissan 300ZX forum - Try starting the car with the tps sensor(oval connector)
Evan_Wright (Ca)
on November 23, 2012 at 8:01 PM
Re: here you go tps mod is in there
posted by puchy
on November 23, 2012 at 06:12 PM
un-plugged. Then plug it in after 10 seconds of idling. IIRC that is how you teach the ecu the new closed switch setting.
TPS close switch adjustment after 60mm install....
puchy
14:31:52 11/23/12
There is a mod for it somewhere around here
Krazyd27(Houston)
14:56:09 11/23/12
Krazyd27(Houston)
15:07:20 11/23/12
puchy
15:50:29 11/23/12
puchy
18:12:05 11/23/12
Try starting the car with the tps sensor(oval connector) -
Evan_Wright (Ca)
20:01:25 11/23/12
Re: Try starting the car with the tps sensor(oval connector)
puchy
22:24:03 11/23/12
The Idle On status can be obtained by either the Idle Switch
Gordo 93TT Daytona
22:41:35 11/23/12
Re: The Idle On status can be obtained by either the Idle Switch
MaxxAction
23:48:24 11/23/12
puchy
11:13:30 11/24/12
